Brand new...all bits, bobs and pieces (everything in diagram) included. Thanks for looking.
$OLD
Some additional info from manufacturer:
Metron 5D integrated handlebar, the stiffest and most aero integrated handlebar and stem system. Mixing aerodynamics and ergonomics, the unique shape includes our Aero-Ergo central section. With a slight rise from the stem clamp and a 10 degree forward bend, the 5D accommodates the natural position of your arms for more comfort and easier breathing, while the wing-like shape of the bar top aids aerodynamics. Reinforced carbon fiber construction gives a great strength-to-weight ratio. The 5D features internal cable routing, with guides that accommodate wiring for electronic shifting.
FEATURES
SPECS
$OLD
FEATURES
- —Continuous carbon composite construction
- —Aero-Ergo flat-top riser central section follows the natural arc of the arms with a 10-degree forward bend for more ergonomic climbing position and easier breathing
- —Cable groove compatible with new Di2 systems w/ larger internal cable tunnel
- —Reinforced and textured lever area
- —Color: UD carbon finish
- —Color graphic options: gray
SPECS
- — L110 x W400, 420, 440mm(c-c)
- — Compact 125mm drop
- — 80mm Reach
- — 2˚ outward bend
- — Weight: 395g (420mm)
Pelotontopodium: Jun 7, 17 14:18
