54cm Cervelo P3 with internal 7970 Dura Ace Di2, 3T Brezza II Team Stealth bars, Fizik Arione saddle, Zipp stem, aero front brake, NEW Vittoria tires
For sale is a 54cm 2011 Cervelo P3 with internally routed 10 speed Dura Ace 7970 Di2 components. It features a 167.5mm 53/39 Dura Ace crankset, 12-25 Dura Ace cassette, Dura Ace 7900 rear brake and Tektro aero front brake, Shimano R500 wheels with BRAND NEW Vittoria 23mm Diamante Pro 220tpi tires, 40cm wide 3T Brezza II Team Stealth carbon bars, 70mm 6 degree Zipp stem and Fizik Arione saddle. I bought this bike in 2013 from the original owner who had already had it professionally modified for the internally routed Di2. I only used it as a donor bike for the race wheels and the Di2 shifters/derailleurs (I'm 6'6" and ride a 61cm frame) so it received less than 2 years of riding. The bike is in great shape with some very minor wear from use, including one paint chip on the fork that was touched up with some white paint.
$2350 shipped or reasonable offer.
The non-structural frame modifications that were made to run the original 10 speed Dura Ace 7970 are as follows (also pictured below): small hole drilled behind head tube for handlebar wiring harness entry point; enlarged front derailleur cable hole to fit Di2 connector, enlarged chain stay hole to fit Di2 connector, external and internal bottom bracket shell holes to route battery, shifter, and derailleur wires, battery casing removal, shrink wrap, and added quick connector to friction fit inside the seat post, battery charger mod to add quick connector.
Left side chain stay hole shown above, ever so slightly enlarged right side chain stay hole shown below to fit the connector through
Re: 54cm Cervelo P3 with internal 7970 Dura Ace Di2, 3T Brezza II Team Stealth bars, Fizik Arione saddle, Zipp stem, aero front brake, NEW Vittoria tires [BeyondCategory] [ In reply to ]
Bump.
Bump
Bump for price drop.
Has this been sold?
Re: 54cm Cervelo P3 with internal 7970 Dura Ace Di2, 3T Brezza II Team Stealth bars, Fizik Arione saddle, Zipp stem, aero front brake, NEW Vittoria tires [ahutchinson] [ In reply to ]
Still available.
