2011 Trek Speed Concept 7.0 Medium $1000
PayPal only Please. FREE SHIPPING
- Used and in good condition. 2 owners and neither of us used it much. Father/son owners.
- http://www.ebay.com/itm/2011-Trek-Speed-Concept-7-0-Triathlon-Time-Trial-Bike-Size-MEDIUM-1f-/282602258825?hash=item41cc684189:g:ObcAAOSwVRNZiJuB
- Great performance bike for triathlons or time trial events
- Normal wear and tear with signs of use throughout
- Few marks on the bike and all photographed. Photos 8-9 show chain drop/suck wear it got caught under crank. No crack and stiff to the touch. 5mm is the largest mark
- Frame TCT carbon KVF tube design and fork is carbon with aluminum steer.
- Upgraded Sram grouppo (Originally all Sram Apex). Sram 500TT shifters 2x10 speeds. Sram Force front/rear derailleurs.
- Sram Force double crankset 172.5mm arms 53/39t 130 bcd-normal wear and should last several more years
- Sram Red front brake caliper and the rear brake is Bontrager proprietary brake under the bottom bracket
- Cassette Shimano Ultegra cs-6700 11-23t 10 spd in great condition
- BB90 bottom bracket bearings rotate smoothly
- Upgraded Bontrager TLR 700c wheelset. You will need new rim strips to go tubeless. 24/24 bladed spoke count.
- Continental Hardshell 700x25mm tires with presta valve inner tubes. Tires can last a year or two more
- Speed concept aero skewers with some minor marks on them
- Duotrap cover plate is missing in photo 11.
- Vision tt stock saddle
- Built for height of 5'8-5'11
- Measurements- Stem 110mm +-6 deg. TT center to center c-c- 54cm. ST from center bb to post clamp-53cm. HT from fork crown to stem cap-9cm.
- Plenty of room for adjustment on steer tube.
- Seatpost has plenty of height adjustment
- After arrival I recommend a bike shop rebuild it and do a tune up just for good measure. It requires many Nm specs for re-tightening bolts and a shop would specialize in rebuilding it properly.
- Item ships FedEx and boxed by a local shop. Item ships with insurance and signature.
- Questions? Please inquire
