So I have the Garmin 920xt with heart rate strap that picks up cadence and other run dynamics. Is that enough to use zwift run or so I still need a footpod?
Re: Zwift run and Garmin 920 [justtrime]
You still need a footpod. I use the garmin footpod with an ant+ stick in the computer and it works perfectly. FWIW, I also have the same watch and HR monitor as you and I know it does NOT work without a footpod. I thought it would at first, but it doesn't.
Re: Zwift run and Garmin 920 [jpay]
I wasn’t clear. I am talking about the tri strap that picks up 6 fields of data not the simple hr strap. Sorry for not being clear about that.
I don't have the "Tri" strap, but I do have the HR Run that picks up all those data fields and it does not send the speed to zwift. It will obviously send HR, but you have to pair the footpod as the speed and as the cadence sensor.
Ok thanks.
