FYI there are 3 different profiles used by ANT+ sensors to connect to watches and cycling head units:
- Speed (speed only)
- Cadence (cadence only)
- Speed/Cadence combo (sends speed and cadence data).
Speed/Cadence combo units, such as the GSC-10, send one signal which contains both speed and cadence data to the watch or cycling head unit. Your head unit only sees one device as being paired in this scenario.
Speed and Cadence sensors are treated as individual units will each send a separate data to the head unit. You have to pair each device with the head unit.
You have to make sure your head unit has the correct sensor profile for the speed and or cadence sensor which you are trying to pair. If you have the wrong profile or if no profile is set on the head unit it won't be able to detect the sensor(s).
I used to have a GSC-10 which I used with a 510. Once I switched over to the magnet less speed and cadence Garmin sensors I had to switch the profile on the 510 to pick up the new sensors.
DC Rainmaker gives a brief rundown on the three sensor profiles in the review of the Garmin magnet less sensors.
Quote:
Now it’s important to note that because the two sensors don’t use the ‘combo’ ANT+ profile that some devices don’t support them. Mostly older devices. These days almost everything major on the market supports the three core profiles of: Speed-only, Cadence-only and Speed/Cadence combo. To refresh, here’s how those three profiles are applied in real-life:
ANT+ Speed-only: The new magnet-less speed sensor
ANT+ Cadence-only: The new magnet-less cadence sensor
ANT+ Speed & Cadence Combo: The older GSC-10 combo sensor
https://www.dcrainmaker.com/2014/05/garmins-spd-cad-magnetless-sensors.html What speed and cadence sensors are trying to pair to the 920?
