Check out
https://www.stevehoggbikefitting.com/...1/09/all-about-smps/ The saddle has a flat central part, and as you have noted, tapers off at the lateral edges. The rear, rounded area is 148 mm wide, but not flat (pic 1). Approximately where I think most of my contact with the saddle is, the flat part is about 73 mm wide (pic 2) and the actual saddle is 77 mm wide (pic 3).
That's about here on the saddle (pic 4). You can also see there is a definite scoop which you sit in. I occasionally push a bit further back whilst climbing, and the saddle is 75 mm (pic 5) there.
