Spesh Sworks 6 shoes - moving 5mm backwards
How do you actually move the cleats that extra 5mm backwards? I cannot find any documentation about that.
  • Titanium alloy cleat nuts can rotate to position pedal/cleats 5mm rearward.
Re: Spesh Sworks 6 shoes - moving 5mm backwards [ddave] [ In reply to ]
I've done it, don't remember exactly how, but I think I removed the insoles and then "flipped" the bolts inside the shoe then reinstalled everything
Re: Spesh Sworks 6 shoes - moving 5mm backwards [ericMPro] [ In reply to ]
What do you mean by flipped?
Any chance you could check as to the how you did this? please
inside the shoe are three flaps, covering the three inserts you would thread the cleats to.
you lift the flaps, remove the inserts, and rotate them 180 degrees, thus moving the holes back 5mm.
Make sense?
Make sense?
There seems to be a plastic film over them - is that not waterproofing?
dude, you've exhausted my knowledge... I did it discovery learning style when I did it so your guess is as good as mine ;)
Cheers! Will give it a lash tonight
What exactly is the purpose of moving them backward?
Re: Spesh Sworks 6 shoes - moving 5mm backwards [Fusion] [ In reply to ]
To move the cleats 5mm further back
