lanierb wrote:
Assuming you generally ride in the dry and keep your wheels clean (if you don't, the brake surfaces will wear down first), around 10k they need to be rebuilt -- spokes start breaking etc. For me, in the 10-15k range the hub and/or rim will crack.
Huh, I don't see that. I'm non-gentle 175lb. bike racer, and I've done two rebuilds in over 100k miles of riding over 10 years or so. And I've never cracked a rim or hub. I've worn out brake tracks on rims that never needed rebuilding.
I typically run non-stallion HED wheelsets, though my current trainers are Flo 30's with factory 24/20 spoke count.
Then again I know some 130lb. bike racers who seem to have non-stop wheel drama, so maybe my experience is atypical.
To answer the OP, I don't race on training wheels, though. Because I use different tires. And given that I race frequently (bike racer), swapping tires frequently is annoying. Also I want to know the race tires are reasonably free from crap, and not full of cuts and embedded bits of metal from training rides.
Also it's typically a bit quicker to change flats on training wheels. No valve extenders, etc.
