SharkFM wrote:
Andrew Coggan wrote:
Research has shown that 1) the "vast majority" of amateur runners are not overstriders, but instead have self-selected the stride length/rate that is optimal for them, and 2) the human eye is generally a poor tool for evaluating running biomechanics.
Let me switch sports:
Research has shown that 1) the "vast majority" of amateur swimmers do not take big diggers, but instead have self-selected the kick pattern/rate that is optimal for them, and 2) the human eye is generally a poor tool for evaluating swimming biomechanics. Now if you said that to a coach on-deck they'd say your nuts.
I see running as no different. Cadence first, but also build length (eg. long stride walking, drills etc)
This is definitely an incorrect (albeit reasonable sounding) extrapolation.
Humans were innately evolved SPECIFICALLY for optimal running. We are better at long (ultralong) distance running than any animal on the planet, with special adaptations - no hair for cooling, near-unique achilles tendon (most mammals lack this), weight centered in the head where it won't interfere with running, and a brain that allows us to hunt long-distance and long term by tracking over hours/days.
It's been well studied and documented in top science journals that the foremost experts agree upon - humans have a brain and body specifically adapted to running long.
This is NOT true for swimming, which is why swimming require so much technique work. Any running coach who is trying to use the swimming training methodology to alter one's distance running form will almost certainly make things worse, as your body/brain will choose the optimal stride and cadence for your build AND ability. The faster you go, the more Kenyanlike you'll look.
Bottom line - it's a big error to use the technical training example of swimming and apply to running. Similarly, it's a big mistake to tell newb AOS swimmers to 'just swim with zero technique training like you do in running' as your brain won't naturally pick the optimal stroke pattern.
