Any Ultra-Torque crankset will run with any Ultra-Torque cups. regardless of whether they are Chorus, Record or Super Record. E.G. when you receive a set of press fit cups for Ultra-Torque you either leave the seals in (Record or Chorus) or pop them out (Super Record). The only reason you pop out the seals for Super Record is that the Super Record cranks run the FAG Cronitect (i.e. CULT) bearings. Those bearings barely need lubrication. They are designed for extreme usage like unlubricated in salt water. Grit doesn't seem to effect them (great winter bearings). So, a few drops of oil (of any kind) is quite sufficient and the lack of seals is of no consequence to them.
I think one of the biggest reasons to run SR cups is that they are always black (rather than Record's grey) so they are far better from an aesthetic perspective. Functionally, identical.
