A lot of great answers and plenty of food for thought for me, thank you all! Actually now I consider working on my current position and maybe just buying the new wheels. I will probably eventually buy the new bike in the future anyway, but maybe I will save some more money and buy some non-entry level bike in the 2019 – I'm planning to move to longer distances then.
@exxxviiii
Thanks for clarifying the info concerning the latex tubes, I will definitely try them in the upcoming season!
MattyK 1) Yep, rotated offset post.
2) Specialized Phenom moved as much forward as possible, The photo was taken when I was first sitting on that saddle I think that now I am a little bit more forward on it. But thanks for the advice, maybe I'll try to borrow some ISM saddle (or similar one) and test it.
3) I'll try to remove the spacers to get the stem lower first, than maybe I'll try changing the stem. Thanks!
@scott8888 Quote:
My first reaction to your fit is that you are on too small of a bike and even moving a bigger road bike would yield a better position. You just look really cramped and could benefit from more reach (and given you are already running a decent number of spacers the increase in stack won't be a deal breaker). While you are considering swapping bikes I might also look at going to a shorter crank arm so if you do go lower you won't cut off your hip angle.
Hmm, might be the distorted photo perspective, I am 180 cm (5'10''~) and my bike is M – 56 according to Canyon's sizing, I feel quite comfortable on it (however I have quite good hip mobility). Guys that I know who ride 58 frames are at least 5cm higher than me, but of course I know that the sizing differs between the brands. Noted on the crank length, thanks.
@Barry s.
My transition times are usually comparable to competitors from my level, and if there are some PROs in the field they are 15-30s faster than me. I do the flying mount and dismount quite well, but I think I can improve the way I take off my wetsuit, and try to run a little bit faster in the zones ;). So I agree, there are still some really “cheap” seconds to gain there.
Quote:
OP can also put the aerobars under the base bar, yes it's a tight fit. But will drop him much lower. I have had both bikes. If anything aero helmet was biggest speed gain
First I think I will lower my stem by removing the spacers, then maybe I will try with some further modifications.
lacticturkey Seat is already past the bottom bracket. Thanks for the rest of the hints that you've provided, I need some time to digest and try to implement them.
