Hello,
First of all just wanted to say that this is one of the best forums I've been ever been on. Super helpful advice all-around.
In trying to fit my slight oversized Planet X Tri bike (XL size), I am looking at either a 70mm 17 degree or 35 degree stem. Right now I am running a 110mm adjustable stem. I found a comfortable position with the stem at 35 degrees. However the 110mm stem length too long as I can't comfortably get my elbows at a 90 degree angle on the aero bar pad. I figured shortening the stem length by 4 cm will help with this.
Is a 70mm 17/35 degree stem too twitchy with tri bars or will it be ok if it makes for a better fit?
Thanks
Thanks
