My struggles with calf strains led to the following compilation of advice.
YMMV,
Scott
Calf
Bump 12/12/15
Bump 8/2/15
Self-diagnosis: Grade 1 strain
Grade 1 calf strain is a minor tear with up to 10% of the muscle fibers effected. The athlete will feel a twinge of pain in the back of the lower leg. They may be able to carry on playing or competing in mild discomfort. There is likely to be tightness and aching in the calf muscles two to five days after injury.
http://www.sportsinjuryclinic.net/...hin-pain/calf-strain Rehab:
Avoid hills and jumping until 6 weeks post-injury. Discontinue taking any NSAIDs.
Continue strengthening and postpone return to running until 1-leg heel raise matches uninjured side.
Resistance bands can be used initially, followed by calf raises and then eventually single leg calf raises. Remember not to do any exercises if they are painful. Once you can acheive 3 sets of 20 single leg calf raises, pain-free gradually incorporate running into the rehab program. Eventually plyometrics or hopping exercises should be done to return to full match fitness and prevent the injury recurring.
Running:
-- warmup 15 min on the bike
-- walk 5 min to further warm up
-- run 10 min (not run walk interchange as this is worse for the muscle) at 80 pct of long run pace, stop if tight or painful. Track or treadmill
-- run with compression calf sleeves
-- stretch well afterwards but not before
Do that every other day for a couple of days, then run 15 min instead of 10, then 20 then 30
No speed work or hills for another 3 weeks but okay to ramp up duration as per above to about 40 min over those 3 weeks
http://forum.slowtwitch.com/...on%20sleeve;#4930105 **********
Step 1. Stay off it for as long as it takes to heal completely. I recommend at least a week. Do some wet vesting or cycling, but don't run just because it feels better after a day or so.
Step 2. Get as much massage – including self-massage – as you can, TheStick massage tool has been invaluable to me in this regard (because this injury is in deep, icing has not been as helpful as it has for most injuries). Definitely don't stretch your calf yet. Let it heal first.
Step 3. This step is the real "secret" to recovering quickly from this injury. I've found that it can cut recovery time from weeks or months to days. After a week of no running, start back with a "medicinal workout" on a track or another flat, controlled surface. Start by walking a mile, then jog very easily for a few hundred yards, and then walk again. Alternate between walking and jogging for three or four miles or until your calf begins to feel numb or sore. Then stop immediately. Your goal is to get as much circulation to it as possible without re-injuring it.
Step 4. If you get through the whole session and your calf still feels good, you're still probably not healed, but you're on your way. Take a day off and then repeat the procedure. Do this every other day for a week; increasing the jog portion of the workout as your calf improves.
Step 5. After a week of the medicinal workouts, try a short, very gentle run of three to four miles, on as flat a surface as possible. As always, if your calf gets numb or the sharp pain reappears, stop immediately and walk back. Remember the cyclical nature of this injury. Keep adding to your mileage and intensity day-by-day, but be ready to retreat at the first sign of trouble. After a few such runs, if you haven't overdone it, you'll be back to your normal routine.
Step 6. The long-term key to prevent a recurrence is just to stretch the hell out of your calves and Achilles tendons. I use a homemade, 45-degree stretching board in my office, which I try to get on several times a day, standing on the high end and lowering my heels as far as I can.
Again, make sure the injury is completely healed, and then make serious calf stretching an integral part of your routine. Continued use of TheStick is also highly recommended, both to mitigate any scar tissue and to keep the muscle and sheath as flexible as possible.
http://www.runnersworld.com/...-attacks?page=single
