Fair enough!
But if you go above a few kg per rim it may become wise to take precautions against the possibility of crashes.
IT would be considerably cheaper, easier and more adjustable to add weights on the spokes adjacent to the rim rather than machining a bespoke heavy rim.
If I wanted to know how a bike would handle with a considerably heavier wheels I'd probably do the following:
- Get a cheap set of sturdy touring wheels - say 36 spokes?
- Make up 72 identical weights that can be clamped to the spokes just inboard of the rim, making sure they don't protrude far enough to risk hitting the brakes, fork, chainstays or anything else. Say 120g each?
- Fit a proportion of the weights, say 3, 4 or 6 of them to each wheel
- Ensure the weights are all completely secure and they are evenly distributed around the wheel
- Check the wheel remains in balance
- Test
- Repeat steps 3 to 6 with additional weights each time until you are at full capacity of 36 weights per wheel or until handling or other problems are envisaged or experienced
With 36 spokes and 120g per spoke, that's 4.32kg added to each wheel if you can add them all. So if the wheel is already say 1.2kg, you'll be at about 5.5kg per wheel. That's fairly substantial. I don't know if it's what you had in mind or if you wanted to go further. Obviously with the weights a little inboard of the rim there will be a bit less moment of inertia than you would have for the same mass at a larger radius but it gives you a potential way to get much of the effect with a more practical, cost effective and scalable experiment.
Disclaimer: I am
not recommending you should actually do the above. If you're considering it, I'd certainly say you must do your own risk assessment and determine whether or not it can be done safely. For example, can the bike frame, wheel rim, spokes, brakes, etc deal with the additional loads without distorting or failing? Likewise, can you make the conditions for testing (protective clothing, helmet, environment, etc) safe enough that poor handling won't create a significant safety risk?
Be careful! If it were me, I'd certainly be very hesitant to ride such a contraption at speed.
