Fishbum wrote:
Can someone please explain to me what you're stem options are with that bike. When it comes to a flat or -17 degrees stem do you literally only have two lengths
With the bayonet 3 (non-integrated brake fork) you could get a flat/-17 stem in 90 or 110 mm lengths. The bayonet 4 stem comes in at least a 90, not sure about a 110. A bar with reasonable adjustability should get you into a good fit.
ericMPro wrote:
ctflower wrote:
Fishbum wrote:
The DA does look promising. Why do we not show more love for the Felt DA.
Because it's long and low? Also, I don't think it tests AS WELL as non-UCI bikes.
I think you mean it's *not* long and low
I guess it's on the higher side of low, but I think it would still fall into the greater real of long/low frames, no? It's not the last run of the Speedmax low, but I'd still consider it "low".
