RowToTri wrote:
I think that this begs another question- if we cannot measure the performance benefit of oversize pulleys because if there is one it is beyond the sensitivity of our technology, what is the sense in paying $500 for them?
We can, you'd just need a party with means and/or interest to conduct the testing. I am pretty sure I could figure out how to rig up the mannequin legs and feet and get them to rotate around the bottom bracket at 90 rpms, and all this with error margin between runs significantly less than a gram of drag (call it ~0.1 grams of drag) without removing the testing apparatus. I have that interest but not the means.
CeramicSpeed should have both, but then why would CeramicSpeed conduct complex, expensive tests to show how much or little aero drag the size increase of the oversized pulley adds incrementally to the system. The answer is surely not "less", so there is legitimately no upside to them performing this test and releasing the results. The risk of honesty here is simply too much. They'd rather publish substantive marketing advertorials on frictional gains; acqui-hire the only person/outlet with standing to discredit their internally validated claims; and fly around the world fondling customers' ball bearings at expos. CeramicSpeed even allowed BBLOEHR to use their pump for free! They deserve a medal.
Same with SRAM/3T and 1x. We are supposed to believe that 1x is a big aero gainer when nobody who is pushing the 1x road configuration -- these are the companies who are eulogizing the front derailleur in other verticals; selling high-end aero road bikes without front derailleur mounts; and cooing about the weight reduction potential of 1x while alluding to aero improvements nobody has substantiated -- is incentivized to actually conduct testing that carries only the potential to discredit the conductor. Why test a realistic 1x use case (e.g. no FD, 52T w/ 11-36T or 11-40T) relative to a realistic 2x use case (e.g. FD, 52/36 w/ 11-25T or 11-28T) when you can just assert that the front derailleur hanger itself causes more drag than the entire down tube? There is nothing to be gained by showing that 1x is actually pretty much aero equal to 2x under common use scenarios, so why perform the tests?
Besides that, nobody in triathlon gives a shit about tiny increments of aero, especially when those are increments are actually losses. Now, frictional gains -- those are definitely cool. Haven't you seen Jeff Yingling's instagram? Cool. Very cool.
