Re: Total immersion swimming coach update [ericmulk] [ In reply to ]
Yes 7 days away. Pool was closed 😑. And yes 15 seconds. My swimming is bad!!!! I'm not going to list my 100 time. It's shameful
Re: Total immersion swimming coach update [Fishbum] [ In reply to ]
It would help for context.
I'll post my last 5k time so you can laugh at that, if it makes you feel better.
Swimming Workout of the Day:
Favourite Swim Sets:
Re: Total immersion swimming coach update [JasoninHalifax] [ In reply to ]
No way..it's bad. I should also say I just changed to Training in a jammer from traditional swimming/ board shorts as well. Probably made a big diff as well.
If you were swimming 3 minutes per 100 yards, I could easily see a 15 second improvement in a short amount of time.
Umm, that's 14 of your 15 seconds and 1.75 of your 2 stroke per length improvement right there.
That makes me 😔
At least my stroke count dropped. I'm 5"11 what's a good count per 25
I'm an inch shorter than you and (when I want to) can do 9 strokes across the pool (SCM). that's counting each arm. i.e. pushoff, surface, left, right, left, right, left, right, left, right, left touch.
So you're taller than me in a shorter pool. 8 strokes.
I'll et you decide if I'm serious. I am serious about the first paragraph though....
How far is ur push off? 15 yds?
I'm down to 16 from 19
1-2 dolphin kicks usually. maybe 6 or 7 m off the wall
(that's not my regular SPL. I'm typically 15-16 SPL, but that in and of itself isn't a great stat. If you are doing that but you are excessively gliding* then that isn't good.
* excessive means "at all". good swimmers don't glide. not even sun yang.
If you're Ricky Berens, 9 strokes per length is pretty good. So smooth....
15 yds? You glide for over half the pool?
Re: Total immersion swimming coach update [walie] [ In reply to ]
I was sarcastically asking Jason how far his push off is since he said he can do the 25 in eight Strokes.
Actually, I said 9. Get it right.....
Not sure if I can do that now. That was a couple of years ago, I was in the water a lot more than I have been for the past year, I think I've lost some feel and a bit of power...
Amazing. An update on terry turned into a compare and contrast on turnover, glide, speed, etc. Just sayin
