Tom A. wrote:
I'm probably setting myself up here...but, I've got a bunch of questions about that "data set" (concise answers would be appreciated):
- Do you always do the cadence steps in one direction (low to high)? Do you ever do them high to low?
- Are the HR values an average? If so, over what time span of the intervals?
- Is 200W the power level you intend to race at? If not, are you aware published studies show that the most economical cadence varies with power level? e.g.
- Do you plan to race on unlocked powercranks? If not, then why is mostly all of the testing done that way? De-coupled crank pedaling performance does not equal coupled crank pedaling performance.
- In regards to the question above, did you happen to notice that of the few tests you've done with the cranks locked (coupled cranks), those tend to show the lowest HRs overall? If lessening HR in your bike leg is your goal, then why do you think that is?
As you can see by looking at the data, the first tests, from 9/17 to 10/4 where from high to low, after that, low to high. We got rid of the over 90 since I really cannot pedal well at 100, let alone could never hold 110 rpm.
Ideally, HR would be average for the time period, but I found no easy way to do. So the HR numbers are at the end of the period. This method has been used for all the HR numbers collected.
Again, we are just collected data for a fixed setup, with only one change at a time. This way we can see with one change, just Cranklength and fit, what happens.
I have even left the gearing alone to not impact being able to compare the data. Since I do not have a power meter on my bike, I have zero idea what happens in a race, I just go as fast as I can. Now, sure would love to get a power meter for the race bike now. :)
Not sure what Frank will suggest about racing. Today, all I have are normal 200 and 175 compact cranks. I basically can ride PC's just like regular cranks.
That question is in my mind though. Frank believes that PC's allow a rider to develop a more efficient pedal stroke I know the vocal ones, who have never tried PC's, do not agree. (I hope they never do one legged bike drills :)
What I have seen is not HR correlated to the PC's, what I see is a relationship to getting in aero. Those first half tests were 100% done sitting up, and had the lowest HR's. When I added the 50% aero, I am seeing the HR go up 2 to 5 beats when I get in the aero PC's pr locked cranks. Since I have also raced hard twice during the testing, and have been sick, one has to look at more data that just the HR. As an example, I added the field to the far right which is my run time on my 9 mile run route. When my times are over 1:30, my body is not rest, either from a race, or being sick. A lot of testing has been under these conditions. Finally getting over my cold, but still not recovered enough that I have yet to be able to get back on my treadmill. I am also trying to collect resting HR in the morning. Tough trying to remember before I get out of bed, since the HR jumped just walking up my stairs.
All great questions!! This is why I continue to ride and collect more data. Too many things have happened relating to taking HR to just use a small sample size. I have no more races for a while. I hope to not get sick again. So, if I can get my long run times back to 1:27, able to run on the treadmill again for my 6:30 pace, then the HR numbers will be more interesting to look at. If they stay the same, not sure what that will mean. Other than I can easily change things, crank length, use fixed cranks, etc. to keep getting more data.
Wish we were having this discussion on my thread since all great stuff for folks to look at in the future. In a year either I am going to say I was the biggest fool, or. ...
Dave Campbell |
Facebook |
@DaveECampbell |
h2ofun@h2ofun.net Boom Nutrition code 19F4Y3 $5 off 24 pack box |
Bionic Runner |
PowerCranks |
Velotron |
Spruzzamist Lions don't lose sleep worrying about the sheep
