dangle wrote:
Signal8 wrote:
lightheir wrote:
(Not that it would change much - I use a wheelcover disc and like it!)
I propose a race. You can choose to either remove or instal your wheelcover on your PT hub. Meanwhile, I will swap my quarq between my tri and road bike. Done. I win!
*Maybe not to address you specifically, but other readers questioning the Powertap/disc cover side of things.*
This is wrong. You only need the cassette out of the way to get a disc cover on and off. Taking the entire freehub off (with the cassette attached) is SUPER FAST on Powertaps and most wheels in general. Two 5mm hex keys will take off the freehub body (with cassette attached) on many hubs and allow you to throw on the disc cover.
Powertap freehubs pop right off. No tools. The older generations were a little too easy to pop off actually. If it were an actual race as proposed above, the Powertap/disc cover install would beat almost any pedal or crank install.
Link to Slowtwitch article on removing Powertap freehubs -
http://www.slowtwitch.com/...-_Powertap_3486.html Don't get me wrong. I'm not anti-PT hub or anti-disc cover. I actually race with a Wheelbuilder cover myself. Which is why I know it takes longer than a minute to install/remove the cover. I choose to tape the inside of the cover to the DS spokes and tape the outside to the rim to avoid any shifting and/or noise. Granted, my method is more time consuming than the plastic screw method.
Without video evidence, you won't convince me anyone can remove the wheel, remove the free hub (or cassette), remove the cover, replace the free hub (or cassette), and replace the wheel in anywhere near a minute.
With my Quarq, it's literally one 8 mm allen key used to loosen one bolt. Then, put the crank on the other bike and retighten the same one bolt.
Now, if the proposed race involved my two bikes being seperated by a 50 meter wide river that I had to swim across to complete the swap...then I'd surely lose.
