rmt wrote:
I think you're missing the point regarding the reason some people don't see the value in a power meter that measures 1 leg only and doubles it - it has nothing to do with L/R balance being a useful metric, it has to do with the fact that in the case you quoted the power numbers from a single sided meter will be up to 4% wrong. I would agree that L/R balance is currently a pretty useless metric, that doesn't lead to a single sided power meter being accurate though. If you already know you L/R balance you will have a fair idea of how accurate it will be for you, and can make a decision about whether you're happy with that degree of accuracy. In your example you may be quite happy at 4% accuracy and therefore, for you, a single sided power meter is fine. For me a single sided power meter could be out by 10%, and I'm not happy with that accuracy. If you don't know your personal balance, then you are guessing at how accurate the numbers will be, at which point maybe HR or RPE is a better metric to be using.
Even if it were innacurate. As long as you're fed the same lie over and over consistently you can train to that. Now, if you have more than one PM I do see a need for it to be accurate, but if you only have 1, then you do not know any better. I could analogies with current politics but I will refrain
