I'm playing around with my bar, pad + extension setup. I quite like the adjustability of the ENVE bar, and am settling between two options:
1. Pads on bar, slight tilt using washer, extensions under mounted: I love the position, but it seems like a lot of that under-mounted hardware will be hitting the wind. I'm leaning toward this option with the thought that the "better" body position will outweigh the "less clean" mounting option.
2. Pads and extensions above base bar, more tilt available, and looks like it could be much cleaner in the wind. It feels pretty good too.
What are your thoughts on that hardware under the base bar? Should be pretty negligible aero impact, right?
Image below with both options
Are you ready to do an Ultraman? | How I calculate Ironman race fueling | Strength Training for Athletes |
