Rocky M wrote:
13x racer here, 19x KQ, 1 DNF & 1x for their 1/2 IM--I said enough is enough when I decided after that many tries, the cost to go and implode in the heat wasn't worth it. Love going just for the trip to fart around and snorkel, swim, spectate, but the race I just despise and never really enjoyed it except my first time (just because it was my first time). After that, it lost its magic. Typically a non-performer each time racing there. Maybe one day I'll go back, but I have to face it, I'm genetically designed & geared towards colder weather and anything over 75 F is just not a good situation for me to race in. I've tried all the published tricks to tackle that...no dice. No Mas.Here is the thing. The body type that often does well in cooler races which is many of the qualifiers races generates too much heat for Kona itself. You can't escape the physics of each joule of energy that turns to mechanical energy in the bike or run creating 4 joules of heat in your body at the same time. The reason many pros (not all) are fast elsewhere and Kona is because they produce so much energy in cold weather races that they don't actually get that cold, but they have enough surface area to volume (read they are tall and skinny) to dissipate the heat in Kona because on the run, their pace is high enough to generate a bit more cooling air flow than your average age grouper (keep in mind that wind resistance scales with the cube of velocity so even running at 4 min K vs 5 min or 6 min K is a dramatic amount of additional cooling in Kona heat provided that the ambiant air temp is cooler than body temp of 36.xx C...after that you're injecting heat into your body, but it's always cooler than that on the Kona run). In cooler weather qual races, someone who generates a lot of heat at low speed on the run has it sucked away by ambiant air (kind of like a facebook data center in Sweden that uses cooler ambiant air than a data center in Dallas).
I bet you if Lionel loses 5-8 lbs and goes slower on the bike he can go dramatically faster on the run. Lange is 140 lbs, Lionel is 165 lbs. The heat that Lionel generates is dramatically higher (if they go at the same watts per kilo on the bike or run, Lionel is generating in the order of 40W more of mechanical work, which is 160W more heat....or around 1.6 extra 100W lighbulbs heating up his body). I doubt Lange can touch Lionel on a cool day in Arizona just because of the physics at hand.
Related to this I would counsel Tie3 to find the hottest mountaineous race he can find to try to KonaQ. That boils down to Nice in June (assuming he can technically handle a bike in the mountains) or show up again in Whistler and hope for a 35C climb out of Pemberton and a scorcher on the run. Or maybe a sauna humid hot day in Cabos or Malaysia or Taiwan.
