AndyCaleb wrote:
Quote:
proper gym flooring in pain cave 2.0
Excuse my ignorance on this, but what constitutes proper gym flooring? I tried to research this a while back but couldn't find an option that does not smell of rubber. What do you recommend?
"Proper" gym flooring is nothing more than stall mats that have been cut so that they interlock. You could go to your local feed/tack store and check stall mats, usually 4'x6', in varying thickness. I've used both 3/8" and 3/4". That 3/4" though is VERY heavy.
These are also often made from recycled tires. Thus the smell. It eventually goes away, though.
With all of these, however, there is the issue of mold underneath. Concrete floors are not sealed, in general, and are permeable. Thus, water will come up through them from the ground. If the surface above that concrete doesn't breathe, mold will develop. Same with wood structures suspended over ground. Use the mat, then pull it up when you're done so the floor can breathe.
Some are born to move the world to live their fantasies...
https://triomultisport.com/ http://www.mjolnircycles.com/
