Hi all,
I recently moved out my TM01 in order to purchase the new model, but I was curious about how much difference I'm buying between the 01 and 02 or Canyon Speedmax CF.
I have Pro Missile Evo bars, Sram eTap, and an Omega front brake to add, which will clean up front and still be pretty easy to travel with. How much would these upgrades reduce the penalty of not buying the integrated versions?
My main concern is the stiffness of the carbon. Is the carbon considerably less stiff on the 02 or CF vs. their premium counterpart? The websites don't give much insight between the difference. I ride in a fairly aggressive position, but I think I will still be able to get low enough in the front without any spacer or find a negative degree stem if necessary. Is there anything I should consider?
onceatriathlet3: Oct 7, 17 10:21
