BigBoyND wrote:
For those who've used the X, what do you have to do to pull the bar off the steerer tube for shipping? On tri bars with rear exits there is typically enough slack. With the X, do you have to disconnect the brake cable from the Omega or is there a way to have extra cable housing slack in the base bar and not use the cable stop so that as you pull the bar up, the extra housing comes out and no cables have to be disconnected?
For the brake, you can pop the wedge out of the assembly by hand, no tools needed, and then you get all the cable slack you need, but without losing any adjustment. When you arrive at your destination, just pop it back in.
For the bars, itβs just two bolts: one at the top cap, one at the wedge clamp. Then everything slides right off.
TriRig.com
