I have a garmin 935 watch. Also have garmin edge 520 on my bike that I use for all bike info. My question is once I figure out how to broadcast the heart rate from the 935 to the edge 520. Is there any advantage that a HR strap would give me. My son works at a retail store and got me the 935 for more than half off retail price. I am just curious if it would be worth while to spend the money on a dedicated HR strap.
Re: garmin 935 [dl1340]
strap heart rate is quite a bit more accurate, especially for non-steady-state exercise.
As someone who does not train by HR, I appreciate the convenience of the optical sensor. But if you actually rely on HR data, the quality of wrist-based sensors is simply not there. It also seems anecdotally to be worse on the bike than when running.
there's a reason that Garmin won't let you use the built in optical sensor for HRV Stress Test. It's simply not reliable/accurate enough. Not that you need to do an HRV test ever for any reason, but it's telling that they acknowledge the limits of the sensor in that way.
I bought the 935 in June and learned a little later how to broadcast my HR to my 510. I can't speak for anyone else or their experiences with this setup. I can only tell you it's been accurate as far as I can tell through my IM build.
This is the reason I bought the 935 (I had the 920).
YMMV
YMMV
I have had the 935 for several months now. It works great. The wrist-based heart rate seems very accurate. I also have the tri-strap to get HR during the tri-swim, but only use it for races. The broadcasting is easy to do- use the lower left button to scroll down to the HR widget. Once there hold down the middle left button. Then select HR Options (by hitting upper right button). You can then scroll to Broadcast HR and select it. As long as you are broadcasting the only thing you see on the watch is HR. Unless you are doing intervals, or the strap is loose, or you are riding cobbles, it seems pretty accurate. For more info read the DCRainmaker review. It is also easy to upload workouts to TrainingPeaks and other apps. Only down side is the basic design- wish they would hire away some of the Apple watch designers and make the watch look cooler, so it could be worn all the time.
Re: garmin 935 [Rappstar]
I wear a Scosche Rythym+ on my upper arm. I find that location provides much more reliable results than if worn on the upper forearm which in turn is a much better location for an optical sensor that the wrist.
Re: garmin 935 [Scott_B]
Scott_B wrote:
I wear a Scosche Rythym+ on my upper arm. I find that location provides much more reliable results than if worn on the upper forearm which in turn is a much better location for an optical sensor that the wrist.This!
It might be better on a road or TT bike than while running. The watch can bounce quite a bit while running and that leads to gaps in the distance to reading against the skin. Road cycling is usually not as bouncy and you *should* get a decent read while using wrist-based optical HR. Or at least better than running.
Zen and the Art of Triathlon. Strava Workout Log
Interviews with Chris McCormack, Helle Frederikson, Angela Naeth, and many more.
http://www.zentriathlon.com
I considered the Scosche before purchasing the 935, but did't like the idea of having a forearm tanline. I hated the chest strap and find the wrist HR pretty accurate.
