Uncle Phil wrote:
It's much easier to do as the others mentioned. Copy all from the PDF, then "paste special" as text into an Excel spreadsheet. If you're lucky it will convert automatically and separate into columns (depending on your version of Excel). Otherwise you can do a text or data to columns and select your delimeters to be tabs and spaces. Then you can sort the spreadsheet and delete all the irrelevant info and text quickly and you're good to go. I just did the list for Chattanooga in a few seconds.
+1
The only trouble i had was people with multiple name fields. Fortunately, I care less about that and more about getting the # of each AG.
808 > NYC > PDX > YVR
2024 Races: Taupo
