I'm having a problem getting the Corsa Speed TLR to set up on my FLO 60. The Flo is the newer all carbon rim. This is the second CS tire I have gotten on the rim without it setup correctly. I'm running the wheels with latex tubes. The tires are not center ing on the rim leaving one side running larger in diameter. They're is no tube under the rim and they are holding air. The first tire I had this problem with I took off and was planning to return it. Then I tried it on a zip disc where it mounted easily and is working great. Several Continental tires have been on and off the rim with out a hitch. Has anyone else seen this before? Any thoughts on how to get them to play nice together?
The tire jack was a must to get the CS on the rim. Thank for the recommendation in earlier threads.
