I've been using an Enve 8.9 wheel set this past season for mostly OLY distance racing (got the last set produced directly from Enve last year). Been satisfied but I'm now thinking of purchasing a rear disc to use with the front Enve. I thought I heard Enve might be making a new disc but would like to hear what others recommend would be the best combo. Budget not an issue....looking for the best option out there.
Re: best rear disc for P5 [gphin305]
Read this
http://forum.slowtwitch.com/...enve%20disc#p6391715
Quote:
Budget not an issue....looking for the best option out there.Without question, the best wheel for you is the Lightweight Autobahn.
Re: best rear disc for P5 [nickwhite]
Mavic's disc wheels are ridiculously overpriced. No reason to consider them.
They are also only available with tubular rims.
jimatbeyond: Sep 11, 17 8:30
Running a HED JET+ on my P5 with no issues. Maybe consider a HED or FLO disc?
-Brad Williams
Website | Twitter: @BW_Tri |Instagram: @BW_Tri | Strava | Co-Founder & Coach at: KIS Coaching
Partnered with: Zoot Sports | Precision Fuel &Hydration | ISM
-Brad Williams
nickwhite wrote:
Are there any downsides? Well, yes and for that reason this can’t be the perfect wheel. There’s certainly no escaping the price, which most of us will equate to robbery. Owing to the exquisite build quality, the price could be forgiven if the Lightweight Autobahn was perfect, but sadly it’s too narrow.
The rim width is only 20mm and we now know that wider tyres offer optimal aerodynamics. Even mounting a 23mm tubular tyre is not suitable, as the tyre bulges and doesn’t sit flush with the rim – something widely considered to be sub-optimal for aerodynamics.
Furthermore, the disc is only available as a tubular. Owing to the removal of the glue interface, clinchers offer lower rolling resistance than tubulars and the fastest tubeless tyres are faster still.
Read more at http://www.cyclingweekly.com/...#bgipHTXmU0580WU2.99
Dash Gretchen
Re: best rear disc for P5 [@BW_Tri]
I thought there were clearance issues with the Flo disc on p5?
Re: best rear disc for P5 [jimatbeyond]
jimatbeyond wrote:
Mavic's disc wheels are ridiculously overpriced. No reason to consider them. They are also only available with tubular rims.
Who the hell is buying those discs!? They're like $3k in Australia.
Re: best rear disc for P5 [mike s]
Any user feedback?
Re: best rear disc for P5 [Epong]
None from me, , leaning towards that one myself when I switch over to clinchers next year
Re: best rear disc for P5 [bilalm]
bilalm wrote:
I thought there were clearance issues with the Flo disc on p5?We are not aware of any fit issues on the Cervelo P5.
Chris Thornham
Co-Founder And Previous Owner Of FLO Cycling
I owned a Lightweight wheel for a while. Of all the lenticular disks I've owned, it was the slowest.
The bump disk rules. And right now, Hed is the only bump disk maker.
My latest book: "Out of the Melting Pot, Into the Fire" is on sale on Amazon and at other online and local booksellers
Re: best rear disc for P5 [Canadian]
It does fit indeed, the P4 is giving problems, the P5 not....
Bert01 wrote:
It does fit indeed, the P4 is giving problems, the P5 not....Yes, the P4 can work, but it's VERY tight.
Chris Thornham
