DarkSpeedWorks wrote:
Tom A. wrote:
So...what do we see? Well, based on the "15% drop" pressures, the Crr values for the 20C and 25C tires are basically identical, while the 23C version is actually slightly higher (by ~.0002 - the Conti vertical axis is in "percent"), which again is nearly the same. Heck, with my roller testing, I consider anything within .0001 to be basically "tied".
So, in the real world, when one uses optimal and realistic pressures for racing on real roads and, of course, all other things being equal, it appears that narrower tires (when mounted on the right rim width for that tire size) are indeed faster when one considers the aero advantages of narrow wheels/tires.
Is this generally correct, or am I missing something?
Yes, I would say that's generally correct. The important factor to keep in mind though is making sure that the road surface conditions (along with rider mass and speed) don't put the rider into a situation where one can't lower the pressure enough to be below the "breakpoint" pressure for the conditions AND avoid pinch flats.
In other words: 'Tis far better to err on the side of too little pressure, than too much...until you risk bottoming/pinch flatting! ;-)
Here's how I look at it now...Josh's (and previously Damon's) data basically shows that for flat surface, 8cm, and 8mm "bumps", compliance is really mostly driven by tire pressure.
https://silca.cc/...r-is-stiffer-harsher So, if conditions require lower pressures for both comfort, and for avoiding "breakpoint" losses, then the use of a wider measured tire width is valuable, since as a byproduct, it's also taller, which helps to avoid bottoming. This widening can be done by using a wider inner bead width rim on a given tire, or a larger tire...or both.
Once you've arrived at the preferred pressure, then for timed racing on paved roads, you're going to want to run the narrowest width combination that allows that pressure without undue chance of pinch flatting and/or rim bottoming. That will give the best combination of Crr and aero drag.
