Finish line is up here...seems like a joint venture with the German Max Planck Institute:
Stage profile says it all. A real grind with extended climbing. It is bit more difficult than the longer climbs that Contador lost 3 minutes on during week 1:
First climb looks a bit harder than Alpe d'Huez ending with a 15 percent grade. I assume some of the GC guys will go hard close to the summit to break the chasers and whittle down the group. I suspect Contador will want to go hard here to lose some of the guys in between him and the podium. Froome and Sky will be happy to play along to loose a bunch of people and put them out of contention. :
Then a quick descent and then 15K uphill:
There is nothinig ultra super duper steep here overall given that it flattens out in the second half. I suspect Sky will put down the hammer late on climb I and keep the throttle on full bore for another 7K until they get into the flatter part and just ride tempo to the top and however comes with them is fine, but they will try to eliminate as many threats as possible. Orica Scott should have some cards to play on the second half of this with 2xYates plus Chavez.
This should be a stage that Teejay can hang in the entire time for BMC....but let's see.
Top 10 after 10 stages, Contador sitting 3 minutes outside a podium
General classification after stage 10#Rider Name (Country) TeamResult1Christopher Froome (GBr) Team Sky40:12:44 2Johan Esteban Chaves Rubio (Col) Orica-Scott0:00:36 3Nicolas Roche (Irl) BMC Racing Team 4Vincenzo Nibali (Ita) Bahrain-Merida0:01:17 5Tejay van Garderen (USA) BMC Racing Team0:01:27 6David de la Cruz (Spa) Quick-Step Floors0:01:30 7Fabio Aru (Ita) Astana Pro Team0:01:33 8Michael Woods (Can) Cannondale-Drapac0:01:52 9Adam Yates (GBr) Orica-Scott0:01:55 10Ilnur Zakarin (Rus) Katusha-Alpecin0:02:15
devashish_paul: Aug 29, 17 18:49
