jaretj wrote:
If you had a functional threshold power of 260 watts and your power at VO2max is 280 watts you would likely benefit from doing some work at VO2max.
If you had a functional threshold power of 260 watts and your power at VO2max is 320 watts you would likely benefit most from doing Threshold work.
Hmm. So you're talking about VO2Max as established in a lab where one uses breathing apparatus? The only # I have for V02Max is the one calculated from my FTP, so my delta between FTP and VO2Max is just some generic rule of thumb.
I guess I never really considered that some people might have a VO2Max much higher than FTP, and others might have a VO2Max not much higher than FTP.
If I understand your point correctly, you're saying that since I'm not racing at bike VO2Max, there's not much need to focus on VO2Max in training vs focusing on training at FTP intensity. The caveat being that if VO2Max and FTP happen to be pretty close, then training at VO2Max pretty much is training at FTP. That a correct summation?
Books @ Amazon "If only he had used his genius for niceness, instead of Evil." M. Smart
