Like new, this gently used 15' Endless Pool is a self-contained, heated unit that measures 15' x 7', and allows for year-round fitness swimming. We added the Endless Pool pace clock so you can set the desired pace, and always know your swim pace (i.e. 1:25 per 100/yd, 1:36 per 100/meter). Motor can provide a pace from 2:40 to 1:18 per 100/meter. Purchased new in 2013 and used in a garage setting until last year, when it was moved outdoors, and has been in service since April 2016 here in Northeast Florida. Easy cleaning and maintenance with a roll-up cover that keep the leaves and rain out. Also included will be the Endless Pool stainless steel mirror that you can place on the bottom to best monitor your stroke. Originally paid $29,700. Asking $14,500. The pool can be moved without disassembly, and moved on the back of a flat-bed truck. Approx. cost to move pool is $900 - $1000 (within 50 miles) and placed on a concrete pad (17'x10'). Then a simple electrical hook-up and fill again with water and you will be swimming!
Jim Escobar
FIST & Retul Certified Fitter
ProTriFit - St. Augustine, FL
Jim Escobar
