Trauma wrote:
I'm not sure whether they didn't make the cut... It's more likely they haven't applied yet for approval...
The approval process isn't difficult or even lengthy. It's a one-page application that you can find for yourself on the itu website. The toughest aspect is getting independent ISO safety certification for the frame, fork, and seatpost, in all sizes of your bike. This is a very expensive process, and you don't want to undertake the independent certification until you are SURE that your bicycle will pass it. That means that you need to do the testing at the factory level first, before sending to the independent lab.
Most big name manufacturers and factories do all of this testing in-house already, so they know they'll pass when they send out to an ISO lab. I know of a big name wheel company who would send out engineers to the independent lab itself, to ensure that all the testing was done appropriately (torque specs, specific assembly stuff, etc). However, smaller manufacturers may not always have the budgets to do ISO testing, and perhaps wouldn't want to shell out for the independent certification not knowing if their product will pass the standards tests.
For TriRig's part, we indeed perform all of the testing at the factory level, to ~120% of the ISO standard, so we knew we'd pass the independent certification. We sent off our samples and wrote the big check for lab certification. We did this not just to have ITU approval (which is a relatively tiny chunk of the market), but to have an additional independent verification that our frames are safe. Moreover, we decided to make the testing even tougher, and we asked the lab to do ALL of the strength/impact AND fatigue tests on just a single sample of each frame size. Per the testing standard, you can use up to five fresh samples for different parts of the test. So we were prepared with additional samples in case our first one failed along the way. The lab advised that it was extremely unlikely we'd pass all the tests on just one sample. But we did - each Omni sample (Small, Medium, Large) passed ALL of the tests on a single sample. Omni is one tough bike.
TriRig.com
