Sorry, misread your response.
You're welcome for taking the time to look at your videos as you have requested and openly accepted and tried the responses given.
But seriously, Jason, you're stroke rate, without even looking at the videos again, is about 1 second per stroke. Ive seen enough swimming to know. Its probably closer to .9 but you can do the math on that. When you finish reading this post, open up your iPhone or get a stopwatch or look at a clock w a second hand. At that point I want you to FULLY inhale AND FULLY exhale EVERY SECOND. Let me know how long you go before you pass out or see stars or fall over. And be honest in the fact that it is physically IMPOSSIBLE to exhale all of your air in that timeframe... for anyone. Typically a full exhale with force to clear above 75% of your lung volume takes 3 to 4 seconds.
Breathing every 3 or 5 strokes (or really when you need to breath as we do on land) helps you to balance your chemicals within your bloodstream so your brain can stay engaged and you can, as my first email said, notice the asymmetry from either side of your axis (spinal column from brain to butt.. but really through the head and past the feet). This way you can then mimic on your left side, when you're breathing, to the same simpler and more useful movement that is happening on your right side when you are not breathing.
THEN.. when you have a great sense of that rhythm and symmetry difference, you can make changes by doing less! not more. Oh and be faster.
Good Luck
DaveD
Ps please dont hyperventilate and pass out. I am not saying you need to do that to prove my point!
Good Luck
DaveD
