Looking for a crankset, 175mm length with 53/39 or 52/36 chain rings. Would like it to be BB30 compatible if possible. Ideally looking for an older sram red black.
adktriguy46: Jul 24, 17 5:47
I have:
175 Rotor 3D+ FLOW
130BCD only
aero spider or standard spider
Rings can be the standard 53-39
or, you can choose your outer ring and inner. 39-50 inner 53-58 outer options (the higher you go the likely itll be aero)
$229 shipped. Add $20 if you want an aero Ring (no Q rings avail)
Used of course
text if interested 780-0477
area code 903
I will have either a 172.5 or 175, but compact BB30 in a couple of weeks. I know you didn't specify compact, but in case you change your mind. Both are SRAM Red, little use.
Got a Force 22 crankset with 53/39 rings, BB30 but 172.5 length.
I have an Ultegra and a 105 crank with 53/39. 175. With octalink BB. $50 plus shipping.
Habitual line stepper.
Thanks everyone. Found what I was looking for the other day.
