Would like to see a U.S.E. R1/Tula or MORPH bar with hydraulic levers and forearm hugging extensions
Would like to see a U.S.E. Tula bar with hydraulic levers, made to be a bit more lower profile in the lever and basebar areas
wovebike.com | Wove on instagram
Re: Would like to see a U.S.E. R1/Tula bar with hydraulic levers [milesthedog] [ In reply to ]
Though, I do feel that with hydraulic brakes, a lever could be placed in a normal position, but more integrated with the basebar and much lower profile, since it really only needs to be one or two finger actuated and the range of lever motion does not need to be great to provide high modulation. Something like this fine illustration:
Why not just have a wing with a squeezable leading edge for the brake?
Ride it mtb style.
A few guys in the 90's used to use a 14" long straight bar with mtb levers and it seemed to work for them.
Re: Would like to see a U.S.E. R1/Tula bar with hydraulic levers [lyrrad] [ In reply to ]
Ride it mtb style.
I like it. a sqeezable leading edge sounds great. What I personally would really like is a pair of MORPH bars with a the integrated hydraulic squeeze lever. I know GreenPlease's test at A1 for the MORPH bars were good but not as good as could be, but I'd like see an updated MORPH bar with this style of integrated hydraulic brake along with aerobars that hug the forearm like this 3D printed titanium bars SKY is using in the TdF. I think that'd be pretty darn hard to beat aero-wise.
milesthedog wrote:
[..] I'd like see [..] aerobars that hug the forearm like this 3D printed titanium bars SKY is using in the TdF.
If Meld can do custom saddles by having you sit on a foam crush box, no reason to think they couldn't do custom aero extensions. And if they are not interested, this is a great business opportunity for one of you unemployed Twitchers. Who is going to get this started?
Ride it mtb style.
I've often thought about field testing this sort of setup.
Re: Would like to see a U.S.E. R1/Tula or MORPH bar with hydraulic levers and forearm hugging extensions [milesthedog] [ In reply to ]
I haven't talked to Frank in a few weeks but at one time there was talk of a way to use hydraulic MTB brake levers on the MORF bar.
Re: Would like to see a U.S.E. R1/Tula or MORPH bar with hydraulic levers and forearm hugging extensions [GreenPlease] [ In reply to ]
nice - I look forward to seeing updates.
combine the Paul e lever with The One system.... in an integrated aero extension:
Trek engineers had something like this maybe 12 years ago at a tunnel test I attended with them and USPS/Lance. It was pretty awesome to look at and while I never saw the actual data from it, I also never saw it used anywhere so hard to know if it didn't work all that well or if nobody wanted to ride it?
http://www.SILCA.cc
Re: Would like to see a U.S.E. R1/Tula bar with hydraulic levers [joshatsilca] [ In reply to ]
Thanks. I tossed out several ideas up above. Which did USPS test? Thanks
Re: Would like to see a U.S.E. R1/Tula bar with hydraulic levers [GreenPlease] [ In reply to ]
GreenPlease wrote:
Ride it mtb style.
I did...it's not as fast as an old style Vision basebar and levers, nor a Scott 100K setup with the levers inside the loops...
Re: Would like to see a U.S.E. R1/Tula bar with hydraulic levers [Tom A.] [ In reply to ]
Tom A. wrote:
GreenPlease wrote:
Ride it mtb style.
I'd imagine that's because the straight bar was just round, right? Love to see it made flat in carbon but somehow integrating the levers.
