mt2u77 wrote:
Maybe the aero gurus can explain how this works, because I don't see how narrowing q-factor by 17mm changes frontal area of your legs at all. Maybe if you were pedaling like a bow-legged sailor before, but my thighs at "normal" q-factor spacing are pretty much parallel. If I put them 3 cm closer together, I still have just as much leg, it's just placed closer to the frame. So does the aero improvement come not from a reduction in frontal area, but rather from a smoothing of the flow around the legs and/or fairing of the rear part of the bike from air flow? I'm also curious if you did this testing with a disc wheel. Just trying to figure out how this works.
I'm not a guru by any means, but I can offer a few points. I got a wind-tunnel documented improvement of ~7 watts going from a q factor of 149 to 132 (17 mm reduction). I think this may have under-estimated the improvement, because it was the last run of the day and I was getting tired and sloppy. In field testing I gained roughly that much again by narrowing another 12 mm.
I think I misled by discussing frontal area. You are absolutely right that your legs' frontal area is what it is, whether they are 120 mm or 2 feet apart. It's really about how the air flow re-attaches. If your legs are way out there by themselves in the wind, the flow isn't going to re-attach as well. How close your legs have to be for flow to re-attach is probably a factor of the size our your legs, the frame, wheels, and a whole bunch of factors. From my experience, I'm guessing there's an inflection point somewhere between 150 and 130, where there is a dramatic improvement. Previously, I did some testing between 165 and 150 and saw very little difference ( As long as your legs are way out there, it doesn't matter if its 155 or 200).
Incidentally, I am puzzled that many people here believe that socks with a strip on them will gain them 5 watts, but think that bringing their legs 3cm closer together does nothing. ;-)
My latest book: "Out of the Melting Pot, Into the Fire" is on sale on
Amazon and at other online and
local booksellers
