Is there any wedges or other products that would allow you to pitch the arm pads up on the vuka?????
Re: Pad tilt on zipp vuka Aero? [Fishbum]
I got longer bolts and used 2 valve stem nuts on each side to get the tilt.
''Sweeney - you can both crush your AG *and* cruise in dead last!! đŸ˜‚ '' Murphy's Law
Re: Pad tilt on zipp vuka Aero? [Sweeney]
Not sure I understand? I have longer screws??????
What he said is that he used a longer bolt on the front screw of the armpad and screwed on a valve nut and nothing on the "back screw of the armpad" thus creating a higher angle on the armrest.
Speed kills unless you have speed skills!!!
Re: Pad tilt on zipp vuka Aero? [playero]
OK. Were are you placing the valve stem nuts on the basebar. ?? Under or in-between the bar and spacers???
I had a guy in the UK custom make some for me. I can put you in touch if you're interested. I haven't installed mine yet but they seem to fit.
Coach at TriForce Triathlon Team: https://www.triforceteam.com
Re: Pad tilt on zipp vuka Aero? [asellerg]
Sure
Between the armrest and the riser/bar... whatever your armret connect to then you'll want to sammich the "nut/spacer" like so:
Notice the the silver peice sammiched by the armrest and riser, just do the same and you'll attain a higher angle on your armrest like you may want!
Nice. I thought you were putting it in the risers.
How much spacers do you have above the basebar?
I dont know your exact setup that's why i said earlier... some people don't need risers some do anyways, whatever yiur aremest secures to then that's where you're going to add a "spcer" to create a higher angle, for me i think this is a 4~5mm
I wouldn't suggest anything else higher than that as it may distort the actual shape of the armrest at least for me since my is plastic!
Hope that helps a bit!
