Shiv brake cable question
Question....what have others done to prevent their rear brake "cable" on their Shiv from rubbing against their small chain ring like in the attached picture? LBS said just bend it away, but I'm sure it'll eventually work its way back to this position. Any cheats here to avoid this? I do switch from training and race wheels so I am adjusting my brake tension so I can't just cut this cable off (although I could probably shorten it some).
Re: Shiv brake cable question [sharkd] [ In reply to ]
hard to see exactly. On most bb mounted brakes like that I zip tie the cable to the arm of the caliper. ymmv
My Blog - http://leegoocrap.blogspot.com
I bend mine the other direction. Works great. You could upgrade to a TriRig Omega X and solve the cable issue and replace the crappy stock brake.
Re: Shiv brake cable question [treyedr] [ In reply to ]
+1
Shiv stock brakes are garbage... and that's an insult to garbage.
+2
Re: Shiv brake cable question [GreenPlease] [ In reply to ]
I wrap mine all the way around the bolt so it does a 180degree bend and end faces towards other crank arm
GreenPlease wrote:
+2
+3
The TriRig Omega upgrade is well work the investment.
Re: Shiv brake cable question [dyarab] [ In reply to ]
dyarab wrote:
+1
Huh? Shiv HAS a rear brake? ;) There's something that resembles brake calipers tucked near the BB, and there's a brake lever for me to squeeze, but it doesn't do anything.
Front brake is mediocre. Rear is nonexistent.
Re: Shiv brake cable question [Dilbert] [ In reply to ]
I am toying with the idea of putting the tri rig brakes on my Shiv. At one point, I thought I read you need to order two front brakes for them to work properly on the shiv. Are their specific front/rear brake models, how do they differ and which ones do you need?
Dilbert wrote:
dyarab wrote:
+1
Are your brakes adjusted correctly? What about the pads—are they the correct pads for the braking surface on your wheels?
I've been racing on an S-Works Shiv for 5 years. I have had that bike over 50mph on extended, winding downhills, on many occasions. I have never had any issues/worries with the stock (TRP?) brakes. They function as designed, and as used.
ETA: I exclusively train on ProfileDesign TwentyFour/38, and race exclusively on Zipp 808/Super 9, so only carbon wheels w/ carbon braking surfaces.
no sponsors | no races | nothing to see here
Re: Shiv brake cable question [Mike Alexander] [ In reply to ]
Maybe for prior models (?) but not for the Omega X.
All models including the current Omega X are universal. The Omega X comes with everything you need to mount it front or rear on the Shiv or any other compatible bikes.
TriRig.com
Re: Shiv brake cable question [TriRig] [ In reply to ]
+5 or 6. Whatever number we are on for the Tririg brakes. So much easier to set up and use over the stock.
Re: Shiv brake cable question [mattr] [ In reply to ]
+6/7 on changing the brakes to tririg.
The stock brakes are such crap. Plus the dirt would get into the rear breaks and I would have wheel rub all the time.
Re: Shiv brake cable question [KingMidas] [ In reply to ]
Can someone post a pic of the front of their Shiv with a Tririg brake. Does the cable run the same place as the Magura "cable"? The length of the Magura line is really messy looking.
I've changed the basebar too.
Re: Shiv brake cable question [neilridley] [ In reply to ]
The other solution is to put a cut-off wheel on a Dremel and just trim the cable right at the brake caliper.
A lot of good pics on the TriRig website.
http://www.tririg.com/galleries.php?id=2016_09_Tim_Don_Specialized_Shiv
Here's my front. I can snap a photo of the back tonight (but the cable routing on the cable routing on the back is super simple and clean compared to the stock setup.)
______________________________________________
Team Zoot
Re: Shiv brake cable question [gregtay] [ In reply to ]
Very nice....is that a complete TriRig cockpit/stem? I think that is my next upgrade.
yep. AlphaX, Omega X and Zipp extensions.
Team Zoot
i assume the box for the di2 is not large enough for the SRAM blip box...since they don't mention SRAM in their video. Any idea?
Correct. The BlipBox is too large to fit inside the Alpha X.
TriRig.com
