Others are throwing torque specs around and I just want to add some clarity to this.
There are two different versions of the P4. The two can be easily distinguishable by a space between the integrated water bottle and the frame.
- The 1st generation/version had no space between the downtube and the bottle (see below). The max torque spec on this is 7nm. It seemed to be problematic for more than a few people.
The second generation P4 had a larger cut-out area for the bottle (there was a bigger gap between the down tube and the leading edge of the bottle). The reason for the modification was to allow enough space to mount a standard round bottle if desired. The seatpost area was beefed up and the torque spec increased to 10nm.
In both cases, it's a lot of torque and used to cause me a bit of fear to touch the seatpost on my 2009 P4.
However, a few years ago I switched to the "UCI-legal" P4 seatpost, which is a smaller post and comes with a shim to make it work in older carbon P2/P3/P4. It seems to stay put in my frame at far lower torque specs. Maybe the shim does a better job of keeping it's shape and not deforming / slipping under load (?).
...and always use carbon paste!
