11sp Cassette and 10spd hub
Is there any issue with me running my 11spd cassette minus a cog on my 10spd hub? When I had bought the wheels the hub was supposed to be 10/11spd compatible, evidently that isn't that case.
Can I get a deeper threaded lock ring? Adjust my 11spd RD to function on a 10spd cassette?
needing opinions/advice/concernce or Chinese proverbs. TIA
Its a Shimano Ultgera grupo and both cassettes are Ultegra as well.
Re: 11sp Cassette and 10spd hub [HonestYP] [ In reply to ]
Leave the smallest cog out? Not sure but probably not as the locking ring would not fit properly. Edit: can't leave any other cogs out because then the cassette would not stack properly.
How do you know this? Which hub/wheelset is it?
Can't do that. Cogs are closer together on an 11 sp cassette. The pull ratio, how much cable the shifter pulls (and how far the derailleur moves) with each shift, is different.
Ain't gonna work.
I have not tried it myself but Dark Speed say you can.
http://darkspeedworks.com/blog-11speed.htm
What wheels are they.
Removing a cog from 11 sp cassette and installing on a 10 sp hub works fine, just requires tuning the derailleur cable tension. I regularly do this on my older Wheelsets. Works best by taking out the 15 or 16t cog (depending on cassette range).
Re: 11sp Cassette and 10spd hub [Dangs] [ In reply to ]
Yes, but the deraileur stops need to be adjusted as well.
Also need to consider which cog you can realistically take out.
Most of the cogs on the larger end are now in structured combo and to take a cog out of the middle is to compromise the most used part of the cassette in the gear selection you have.
Best to loose the last cog and swap in a new lockcog or if you are lucky, some cassettes come with both of the last cogs already with detents for use as the lockcog.
Keep it 11 speed and buy a cassette from Lasco. lascoconcept@videotron.ca
I have 2 10 speed wheelsets running 11 speed cassettes without a problem.
Yes, you can, with several great ways to do it!
See our write up here:
Greg @ DSW
Re: 11sp Cassette and 10spd hub [DarkSpeedWorks] [ In reply to ]
Greg @ DSW
Thanks Greg, checked out the website earlier this morning and will be making the adjustments when I get home from work!
Now I will have race wheels next week at my race!
Re: 11sp Cassette and 10spd hub [lyrrad] [ In reply to ]
The wheels are Karbon Speed with a Novatec hub on them. I double checked resources on the specific hub from Novatec and everything came back saying it was 10/11spd. I bought the wheels 2 1/2 years ago with the intent of my new bike being an 11spd. Got the new bike and now this hiccup!
Re: 11sp Cassette and 10spd hub [jimatbeyond] [ In reply to ]
jimatbeyond wrote:
Ain't gonna work.
Sure it can.
Did you miss the spacer that goes on so you can run 10speed on an 11speed hub? Could easily overlook it.
You can't fit a Shimano 11 speed cassette on a Shimano hub, but you CAN fit a Campagnolo 11 speed cassette on a Campy 10 speed hub. Rather than getting rid of the wheels you have and buy new 11 speed wheels, replace the free hub body to Campy and use a Campy 11 cassette with. It shifts more than acceptable (the spacing is almost identical between Shimano and Campy 11)
"Suddenly the thought struck me. My floor is someone elses ceiling"-Nils Ferlin
Greg @ DSW
Anyone been able to contact Lasco Concept re. getting 11spd cassettes modified to run on 10spd hubs? They don't seem to answer emails and the phone # leads to dead air.
There are mentioned in the darkspeedworks blog in the link.
Later edit. I may have spoke too soon. On the 3rd try I was able to leave a voicemail. We'll see what happens.
Books @ Amazon
"If only he had used his genius for niceness, instead of Evil." M. Smart
Re: 11sp Cassette and 10spd hub [RangerGress] [ In reply to ]
Hi,
Yes i am still doing cassettes. We are pretty busy here so that might be the reason i missed your call.
best way to reach us is by mail at lascoconcept@videotron.ca
Thanks
Hugo
514-276-7717
Re: 11sp Cassette and 10spd hub [Hugo lasco] [ In reply to ]
Hugo lasco wrote:
Hi,
Thanks
Hugo
514-276-7717
Just sent another email. -Scott
Books @ Amazon
Greg @ DSW
Did a 38mile ride today on the modified cassette, not a single issue shifting! Thank you DarkSpeedWorks. looking to dominate on the corse now next weekend.
Re: 11sp Cassette and 10spd hub [grumpier.mike] [ In reply to ]
Lasco got in touch with me and I'm buying 2x 11spd cassettes. 2 local bike shops that I went to said the 11spd conversion couldn't be done. Thanks guys, this thread really squared me away. Buying a new rear disk and also a training wheel would have been bad.
Books @ Amazon
DIY (if you have a lathe)
Re: 11sp Cassette and 10spd hub [Nicko] [ In reply to ]
That thread was a nice find, thanks.
Books @ Amazon
Re: 11sp Cassette and 10spd hub [audiojan] [ In reply to ]
+1 Running this now. Switched from Campy 10s to Sram e-tap 11s. Just swapped Campy cassettes 11 for 10.
