What budget?
If we're not talking fancy (expensive) bikes with adjustable posts, then I would make sure it's something with a round seatpost, so you can find an aftermarket replacement easily - an offset post that can be reversed. There are OK carbon ones out of China, or 3T do some with fully rotatable heads.
Personally I find swapping seatposts easier than adjusting / flipping the same one around - it allows you to use a tri specific saddle for that and a road saddle in road mode. Mark the post height with some tape and it's a 30 second swap over. Something like an ISM adds a lot of effective seatpost angle too, as you sit right on the front of it.
Front end, road bikes are nearly always too high for a good aero bar position, but that can largely be solved with a MTB stem upside down. Something longish will stop you from being too cramped up. The other thing to watch for is clip on bars that are too high above the base bar.
