I am upgrading my groupset on a bike with roughly 100 miles. I am going to go ahead replace the cables as well but keep the old housings due to everything is ran inside the frame. I have read a ton of comments and it seems like some people say add a coat of lube and some say otherwise. I'm just trying to get a general consensus and experiences explained from anyone who has dealt with this before. Thanks!
Re: Jagwire Shift cables... to lube or not to lube? [clh850]
Generally, no. But what Jagwire housing and what cable, specifically? There are multiple varieties of each, some with internal linings/teflon coatings and some with bare steel. You generally don't want to lube the ones manufactured with their own "lubrication."
It doesn't make any sense to replace new cables or to lubricate them.
Re: Jagwire Shift cables... to lube or not to lube? [jimatbeyond]
Always thought they were pre-lubed.
Do whatever the manufacturer suggests for the product, they just might know it better than anybody else.
Re: Jagwire Shift cables... to lube or not to lube? [trail]
trail wrote:
Generally, no. But what Jagwire housing and what cable, specifically? There are multiple varieties of each, some with internal linings/teflon coatings and some with bare steel. You generally don't want to lube the ones manufactured with their own "lubrication."I just looked at the housings and for some reason I thought they were Jagwire but the are actually shimano. The cables that I purchased are the Jagwire slick stainless. It looks like the shimano cables have a teflon coating.
jimatbeyond wrote:
It doesn't make any sense to replace new cables or to lubricate them.I agree but in this case the cables have kinks in them where they mounted to the front and rear mech's. I have a feeling that if I pulling them through the housings, the housings will be damaged.
Re: Jagwire Shift cables... to lube or not to lube? [lyrrad]
lyrrad wrote:
Do whatever the manufacturer suggests for the product, they just might know it better than anybody else.That's my thoughts as well but you know we just have to complicate things here :)
Re: Shimano housings w/ Jagwire shift cables... to lube or not to lube? [clh850]
Just a heads up. Jagwire makes awesome "Pro shift kits" but the housing is 5mm housing instead of 4mm. It was a royal pain in the ass trying to route that through my frame. They're really nice, and the best shifting I've ever had. Basically it includes an inner housing that's pre-lubed. It also contains little grommets to prevent any dirt from entering that inner housing. Is it worth it? I wouldn't do it again, go with the cheaper stuff.
I've always used a wet lube on my cables
