trail wrote:
RowToTri wrote:
OBut yes, all engines can vary their torque at a given rpm. It has to do with how much fuel you're​ putting in to the engine at that rpm.
But at a fixed load and fixed gearing wouldn't adding more fuel just increase the RPM? Quote:
But normal driving conditions rarely are conducive to that condition. But if you design a series hybrid electric drivetrain you can operate the engine at that point all the time
Depends on how you define "normal driving conditions," but freeway driving is a very common condition that seems very conducive to that condition. I think that's the whole point of the "overdrive" gear? If you add fuel with no change in external load on the engine, then yes, rpm will go up because you have increased the torque. If you do not let up on the accelerator (reduce torque) or increase the load on the engine, the rpm will continue to accelerate indefinitely until inertial loads blow up your engine by throwing a piston through the head or some other catastrophic failure. If you are driving along on a flat road at a constant speed and you depress your accelerator, first torque will increase. This added torque will overcome the inertia of your car (i.e. external load will increase) and the car will accelerate (and the rpm will then increase) until drag forces equal propulsive forces or until the engine blows up as above.
Freeway driving is typically a very low-load situation and not conducive to meeting the max efficiency point of the engine. Can you cruise at 65 mph on a flat highway in your car with the pedal to the metal? Unless you're driving a go-cart on the freeway, probably not. Generally you only hit the point of best efficiency during acceleration or perhaps climbing very steep hills.
Here's what is called a brake specific fuel consumption map for a 1.9L Saturn engine.
The red curve at the top of the colored section is the max torque curve. The curved blue lines are lines of constant power (use right y-axis). The lines delineating the regions of different colors are lines of constant brake specific fuel consumption - i.e. how many grams of fuel are required per kW*hr of energy production. You can also think of them as lines of constant thermal efficiency. The engine can operate at any point underneath the torque curve, given the right conditions to make it happen. The point of best efficiency is going to be somewhere near the center of the darkest red region.
Ed O'Malley
www.VeloVetta.com Founder of VeloVetta Cycling Shoes
Instagram •
Facebook
