Ditto... this is a fun sub-thread. Though, we have probably killed the OP's original question. :)
Bike frame makers are playing with both the layup and carbon. They mix 12K, 6K, 3K, 1K, unidirectional, etc. weaves based on economics and where it makes the most sense for strength. A cheaper frame will have more of the cheaper and heavier weaves with simpler layups. The higher-end frames will have more of the lighter and costlier weaves. And, those frames will also have more difficult layups. That is what drives the performance differences in the frames, and the bike makers market that and premium-price the frames because of it. For a TT bike, the light carbon does not make any sense to me. However, I just built a super light road bike for climbing, so it is a far more expensive frame that uses a lot more of the lighter and stronger weaves. (The super light is not a Pinarello, that is a Franco, though Pinarello uses a higher grade of carbon than Franco uses on my Franco frame. Franco's newest frame they just announced uses the same level of carbon that Pinarello uses on the F10.)
My original comment was that the performance difference between the IAx and IAxx is not that different. Though, because of the shorter head tube, it is possible that the two could be equals, depend on the bar and extension configuration. All other things being equal, just the brake of the IAx is probably faster than the IAxx's exposed brake.
Now I am going back and I cannot find the press release that describes the carbon difference on the Advanced Pro TT frameset from the other Advanced Pro frames. They have an Advanced SL carbon on their website, but the TT frameset page does not explicitly say it uses this carbon. However, the pricing does not make sense either... it is lacking the bento & hydro, yet the frame alone is $800 more than a Ultegra mechanical bike, so the frame is massively premium priced for some reason.
No argument that the GTAP is a stupid good deal. $3,100 for an Ultegra mechanical is one of the lowest on the market, regardless of the performance of the bike. If I were buying a bike right now, I would probably get the Premier Tactical, because it is an even stupider good deal for all the stuff you get. But, that did not exist when I bought mine.
I think I found Giant's chart on Aerogeeks The P5 and Speed Concept are better at low yaw, and then the Giant takes over at higher yaw. I may click more, to see if I can find an independent chart.
Cervelo's BTA finding was that the BTA fills the air gap between the arms and creates a better airflow overall. They wrote it as if they were surprised to discover that. Then they went back and simulated via CFD. So, the nut is that space between the arms is bad, so fill it with something. The vertical bottles typically position below the extensions, so they do not fill that space. It's an interesting read:
http://mx.cervelo.com/...nd-aerodynamics.html
