skankyleg wrote:
Weights are not a wash. The rolling resistance is comprised of the interface between the tire and the road and has nothing to do with what is inside the tire. Rotation weight is HUGE!You really think that what's inside the tyre is irrelevant?
Would a tyre filled with ice feel the same as one filled with water?
You're half right about the interface between the road and tyre being what matters, but it seems to have gone completely over your head that the purpose of the pneumatic tyre is to manage that interface. To provide a contact patch capable of providing traction, the tyre deforms. That flattening of the tyre occurs at the road/tyre interface, and since the wheel is rotating that means that once per revolution every point on the tyres circumference is compressed against the road and returns to normal shape again. That requires energy and THAT is the primary source of rolling resistance. Whatever is compressed is therefore a factor in rolling resistance. So, unless you're using tubeless, the tube is a factor.
You seem to be under the impression that only the outer contact surface is relevant. That is utterly wrong as I hope the above explanation makes clear..
Weight is of negligible importance by comparison.
