Sounds like it is the crack pipe adapter I'm using then. I did a quick check and the opening on my disc is 70mm for the valve stem. There is a 32mm stem length butyl tube in there now. If I added another 20mm on top of the current stem in there (to mimic a 51mm tube) that leaves me with less than 20mm of clearance to get an crack pipe in there.
I have a Topeak one (Schrader actually...But that was my mistake on ordering) and it wouldn't fit with any tube larger than 36mm valve stem length icluding a presta-schrader​ adapter easily. But, the shape of the correct presta only crack pipe wouldn't fit either I think as the profile doesn't appear that much less "high" than the one I got.
