Flash question....what is the fastest tire on zipp 808 firecrest clincher for flat 20-40K time trials, 190# rider? Vittoria Open Corsa TLR? Thanks :)
Re: Fastest tire on zipp 808 firecrest clincher [fastskiguy]
fastskiguy wrote:
Flash question....what is the fastest tire on zipp 808 firecrest clincher for flat 20-40K time trials, 190# rider? Vittoria Open Corsa TLR? Thanks :)"It depends." The shape of the tread of both the Continental Tires - basically all share roughly the same profile - and the Zipp tires themselves are the most aerodynamic. But there are faster rolling tires out there that, in some cases, may make up the difference. The question of whether or not they do is almost certainly a question of yaw angles.
Re: Fastest tire on zipp 808 firecrest clincher [Rappstar]
It depends, I was afraid of that! Would ave speed 27mph help any? And....I've got a conti attack (1st version) on there now, it certainly looks fast. Could I do appreciably better with a newer tire do you think? Thanks again :)
fastskiguy wrote:
It depends, I was afraid of that! Would ave speed 27mph help any? And....I've got a conti attack (1st version) on there now, it certainly looks fast. Could I do appreciably better with a newer tire do you think? Thanks again :)The higher the speed, the more aero becomes primary. I.e., for fast races, choose the more aero tire. For hillier races or races where the pavement isn't good, you can bias towards Crr.
Once the tire has started to flatten, it's time to replace it. Based on my recollection, when Zipp did tests on a new Continental GP4000S vs one with 400-500mi on it, the aero benefit on the latter was almost entirely gone as compared with other tires.
10-4 thanks :)
In my experience, the Conti IIs' tread is better than the Zipp tread when it comes to wet conditions.
Straightenin' the curves; Flattenin' the hills
Coached by Mike Plumb @ TriPower MultiSports
https://www.strava.com/athletes/1149072 - https://www.instagram.com/thoswoods/
fastskiguy wrote:
Flash question....what is the fastest tire on zipp 808 firecrest clincher for flat 20-40K time trials, 190# rider? Vittoria Open Corsa TLR? Thanks :)TJ Tollakson always goes crazy fast on the 20mm supersonic with very few watts relatively speaking. #190lbs might be a little heavy though. I am sure JeffP will chime in.
Re: Fastest tire on zipp 808 firecrest clincher [Thomas Gerlach]
I've been getting away with conti super sonic 20c on an H3 wheel for quite a few time trials. (One flat but that was seriously nailing a pothole)
Is the "new" super sonic 20c even a "thing" now? There was chatter that it's a bit bigger and looks suspiciously like the conti TT 22mm tire (or maybe I just dreamt it?)
fastskiguy wrote:
I've been getting away with conti super sonic 20c on an H3 wheel for quite a few time trials. (One flat but that was seriously nailing a pothole) Is the "new" super sonic 20c even a "thing" now? There was chatter that it's a bit bigger and looks suspiciously like the conti TT 22mm tire (or maybe I just dreamt it?)
I don't have one but it could very easily be the fastest aero tire in production with great RR. We just don't have any good data.
