I am doing a new SRAM 1x setup with oversized pulleys. I looked at the SRAM instructions for 1x but they only apply to the small stock pulleys. Is there a secret recipe for setting up chain length? I am running a 54 with an 11-27 rear if that helps.
Depends on the derailleur you are using.
With that cluster you only need a stock road length cage.
